2017-11-18 12:37 AM
generate code project ====>
The initialization function actually inside the main function。
2017-11-20 12:29 AM
Hello
v.v.010
,I checked with CubeMx 4.23 and t
he initialization functionisnot generated.
Please use the last version of CubeMX 4.23, then if you have again this issue, please share your ioc fileto check with you.
Best Regards
Imen
2017-11-21 09:00 PM
So strange! My project was built with the older version of cubemx (version seems to be 4.22), will have this problem after upgrading to the latest 4.23 version. I just used cubemx (4.23) to build a project that does not really have this problem. Thank you for your reply!
