I2C LL
Chuev.Vladimir
I have some questions about how to start I2C on LL.
Firstly, I rewrote the HAL code in LL and was a little surprised
Why does it take so much code to read the data?
	virtual Status::statusType ReadByteArray(uint8* buffer, uint32 size)  override {
		if (state != Status::ready) {
			return Status::busy;
		state = Status::busy;
		rxDataNeed = size;
		rxDataPointer = buffer;
		rxDataCounter = 0;
		auto tickStart = System::GetTick();
		while(!LL_I2C_IsActiveFlag_BUSY(i2cHandle)) {
			if((System::GetTick() - tickStart) > timeout) {
				state = Status::ready;
				return Status::timeout;
		LL_I2C_DisableBitPOS(i2cHandle);
		LL_I2C_AcknowledgeNextData(i2cHandle, LL_I2C_ACK);
		LL_I2C_GenerateStartCondition(i2cHandle);
		while(!LL_I2C_IsActiveFlag_SB(i2cHandle)) {
				LL_I2C_GenerateStopCondition(i2cHandle);
		LL_I2C_TransmitData8(i2cHandle, GetReadAddress());
		while(!LL_I2C_IsActiveFlag_ADDR(i2cHandle)) {
		switch (rxDataCounter < rxDataNeed) {
			case 0:
				LL_I2C_ClearFlag_ADDR(i2cHandle);
			break;
			case 1:
				LL_I2C_AcknowledgeNextData(i2cHandle, LL_I2C_NACK);
			break;
			case 2:
				LL_I2C_IsEnabledBitPOS(I2C_CR1_POS);
			break;
			default:
			break;
		while (rxDataCounter < rxDataNeed) {
			if ((rxDataNeed - rxDataCounter) <= 3) {
				switch (rxDataNeed - rxDataCounter) {
					case 1:
						while(!LL_I2C_IsActiveFlag_RXNE(i2cHandle)) {
						*rxDataPointer = LL_I2C_ReceiveData8(i2cHandle);
						rxDataPointer++;
						rxDataCounter++;
					break;
					case 2:
						while(!LL_I2C_IsActiveFlag_BTF(i2cHandle)) {
						rxDataPointer++;
						rxDataPointer++;
						rxDataCounter += 2;
					break;
					default:
						rxDataPointer++;
						rxDataCounter++;
						rxDataPointer++;
						rxDataPointer++;
						rxDataCounter += 2;
					break;
			} else {
				rxDataPointer++;
				rxDataCounter++;
				if (LL_I2C_IsActiveFlag_BTF(i2cHandle)) {
					rxDataPointer++;
					rxDataCounter++;
		return Status::ok;
Secondly, the amount of HAL code to work with interrupts was too large
I have not been able to port this code. Does anyone have working code to read and write using interrupts?
Unfortunately, the cube examples have code that only reads data
4 REPLIES 4
Why rewrite HAL if you're just going to do the same thing? I2C is more complicated than UART or SPI because of the two-way nature of the communication and the need to check for ACK/NACK on every byte, and if you want to check timeout conditions.
Nikita91
Lead II
There is a lot of code because this I2C IP is poorly designed, and has special cases for 1 byte, 2 byte, and more than 2 byte messages. There are also places where it is absolutely necessary to inhibit all interruptions to guarantee the timings. I've never seen these complications with other MCU vendors.
I was able to rewrite other interfaces with greater efficiency. The code is smaller and faster. But I2C gives me a headache. Due to the fact that I have no idea how it works, I could not optimize the code
Study the description and block diagram in a reference manual. HAL code is a broken bloatware, don't waste time on studying it.
