I2C GPIO PINS
GErma.1
Hi
My understanding is that possible to use the i2c interface on any GPIO pin. Is this statement correct?
BR
Gilberto ​
1 REPLY 1
No, the I2C peripherals are only available on certain pins.
You can emulate I2C using any GPIO pin using an open-drain output, but that's typically not desireable since it ties up the CPU.
