2022-10-11 10:32 PM
I am using IAP program of stm32f207 for the same, but it is not working. Please suggest me for the implementation.
2022-10-12 01:16 AM
Hello @ASing.26 and welcome to the Community 🙂
I advise you to have a look at the IPA example available with STM32CubeF2 MUC package:
Hope this helps you!
Imen
2022-10-12 03:16 AM
I have used this example, but it is not working properly in my case.
2022-10-12 04:21 AM
2022-10-12 04:21 AM
2022-10-12 05:52 AM
Make sure the PLL settings and HSE_VALUE define reflect the clock speed you're using.
2022-10-14 08:34 AM
Hi @ASing.26 ,
Were you able to resolve the issue you described in this post?
Maybe the problem is in your Tera Term settings!
If your problem is solved, please share the final solution you found and mark the reply as Best answer.
Imen
