I'm using the stm32f0 series. I have it right now, so I'm doing it with a signal generator. I want to count every rising edge of the signal my code is as below but it is not counting prope
hdemi.1
5 REPLIES 5
gbm
Principal
Use the measured signal input as timer clock input. You cannot use capture function reasonably at 10 MHz.
My STM32 stuff on github - compact USB device stack and more: https://github.com/gbm-ii/gbmUSBdevice
How fast is the STM32 clocking?
Not counting properly? Please expand on what it is doing..
Should be using External Clock modes, probably not measuring cycles.
waclawek.jan
> TIM_ICInitStructure.TIM_ICPrescaler = TIM_ICPSC_DIV2;
Why? (although I don't think this makes any difference in this particular case)
> TIM1->SMCR |= TIM_SMCR_SMS_2 | TIM_SMCR_SMS_1| TIM_SMCR_TS_2 | TIM_SMCR_TS_1;
That's TIM1_SMCR.SMS = 0b110 = Trigger Mode.
You probably want 0b111 = External Clock Mode 1, don't you.
Plus all the questions of TeslaDelorean.
hdemi.1
I don't quite understand what you mean, can you give an example?
I expect it to count every time a rising edge in but it doesn't
