I am not sure about the difference between the following two
HAL_TIM_IC_Start(&htimX, TIM_CHANNEL_Y)
HAL_TIM_IC_Start_IT(&htimX, TIM_CHANNEL_Y)
‎2023-05-15 11:28 AM
‎2023-05-16 12:31 AM
Cube is open source, so you can look it up yourself. Also, functions in Cube have descriptions as comments before them. Also, the naming follows a convention described in each Cube's User Manual, e.g. for 'F4 in UM1725 (where the description of individual functions is repeated, too).
‎2023-05-16 6:28 AM
Hello @Najam​,
As you can see in any product HAL user manual or any CubeFW example;
HAL_TIM_IC_Start: Starts the TIM Input Capture measurement.
HAL_TIM_IC_Start_IT: Starts the TIM Input Capture measurement in interrupt mode.
if in your application, it is required to know when a PWM pulse starts or stops, the way to do it is by generating an interrupt by calling the IT version of the function.
‎2023-05-18 7:36 AM
I am still not able to understand the difference between "TIM Input Capture measurement". and "TIM Input Capture measurement in interrupt mode". I have not been able to find code examples.
The UM1758 document has one line definitions it does not explain, there is not detail.
‎2023-05-18 7:45 AM
The UM1758 (Description of STM32F0 HAL and low-layer drivers) document has one line definitions it does not explain. There is not description.
This answer was very helpful thanks.
Had I understood this from the documentation I would have not asked the question.
‎2023-05-18 12:48 PM
As I've said, Cube is open source, so you can compare the content of those two functions.
PS. Here is an example using HAL_TIM_IC_Start_IT() - they may be more, I did not search thoroughly
