I am Getting into the Default handler in the startup file while enabling the LL_SPI_EnableIT_TXP(SPI1)?
‎2022-07-13 10:12 PM
Hi Team, I am using the stm32h745zi-Q as my development board. I am working in the SPI in the low level . But When I am enabling interrupts like LL_SPI_EnableIT_TXP(SPI1); and debugging the code It is getting in to the default handler in the startup file . could you please what are the modifications is needed to come out from this.
Thank you
SM
SPI
STM32H7 Series
‎2022-09-30 8:56 AM
Hello @Sm.2​ ,
I was wondering where this function LL_SPI_EnableIT_TXP(SPI1); is declared,
Does it come from another driver ?
Please can you specify whether you declared SPI interruption in stm32h7xx_it.c file?
If yes, can you set a breakpoint to see whether it is reachable?
‎2022-09-30 6:44 PM
If the OP still needs help with this...
Align the vectors table on 0x400. 0x200 alignment is not enough for STM32H7.
‎2022-10-03 5:55 AM
void SPI1_IRQHandler(void) {
/* TODO */
Did you write your own IRQHandler, something like I wrote above?
