How to use FA_OPEN_APPEND in sd card
dbgarasiya
Senior II
I want to write data to already created file in sd card
I have tried use of FA_OPEN_APPEND
I am not able to write data in that file
Best Regards
Dipak Garasiya
5 REPLIES 5
dbgarasiya
Senior II
Any One ,Help me out
Getting errors?
Seeking to the end of the files?​
What is happening?
Posted examples of adding​ line to a log file to the forum previously, look at those.
Had this for incrementation updating
  1. ...
  2. // Incremental write test
  3. if (f_open(&fil, "LOG.TXT", FA_OPEN_ALWAYS | FA_WRITE) == FR_OK)
  4. {
  5. UINT BytesWritten;
  6. const char string[] = "Another line gets added";
  7. f_lseek(&fil, fil.fsize);
  8. f_write(&fil, string, strlen(string), &BytesWritten);
  9. f_close(&fil);
  10. }
dbgarasiya
Senior II
Thanks for replying ,
that working fine
and ofcourse i have another method which i am sharing with you is given below
if(f_open(&SDFile, "sdtest.txt", FA_OPEN_APPEND | FA_WRITE) == FR_OK)
int len = f_size(&SDFile);
if(len != 0 ) len+=2;
f_lseek(&SDFile,len);
res = f_write(&SDFile, wtext, sizeof(wtext), (void *)&byteswritten);
if((byteswritten > 0) && (res == FR_OK))
printf("SD Card written successfully \n\r");
f_close(&SDFile);
Thanks for helping
dbgarasiya
Senior II
Thanks for supporting
