How to use DMA to change PWM frequency?
Xli.1
hi guys. I want to use DMA to change the PWM frequency in the pwm running. I used DMA to change the ARR of Tim, but it was failed. So how to change the pwm frequency by DMA?
2 REPLIES 2
By changing ARR of TIM. You'll need to have ARR preload enabled (TIMx_CR1.ARPE=1)..
Post details.
