2022-08-08 12:52 AM
Hello
I'm using a stm32L431 with an STLinkV3
https://www.st.com/en/microcontrollers-microprocessors/stm32l4x1.html#documentation
HSI is enabled at 16MHz for USART2, used to receive a 1200Bd signal.
I receive wrong characters because of the trim.
I understood the principle of trim and its registers, in particular thanks to this doc
dm00425536-how-to-optimize-stm32-mcus-internal-rc-oscillator-accuracy-stmicroelectronics-2.pdf
My question: is there a way to adjust this trim automatically via cubeIDE and stlinkV3?
Maybe another solution less practical but more practical than a manual adjustment?
Thanks in advance
2022-08-08 11:08 AM
L431 has autobaud rate functionality on USART2 !
I'm not sure I understand ABRMOD and ABREN. Is the correction done automatically permanently by the usart?
2022-08-09 5:50 AM
It's definitely not a TRIM problem, I was able to reproduce the problem with a usb converter that knows how to transfer data as well.
I opened another topic: parity problem
Thank you very much for your help and clarification.
