How to Transfer Data use of simple GPIO pins micro Controller to micro Controller?
Ss.61
*How we can transfer (eg:2 bytes of ) data through simple GPIO pins without using any of the communication protocols (uart,spi,i2c,etc..)
6 REPLIES 6
By bit-banging the same communication protocol.
Javier1
Principal
If you dont want to use any already available communication protocol you need to create your own! (FUN!)
In that case you would have to make a lot of choices, how many gpios can you spare? how fast you need the data transmision to be?, serie or pararell data, or both?, Error check?
Available for consulting/freelancing , hit me up in https://github.com/javiBajoCero
The OneWire protocol exists for this (among others).
https://stm32f4-discovery.net/2015/07/hal-library-05-onewire-for-stm32fxxx/
This appears to be master only.
I interpreted the question as a one way transfer. Could be wrong, it's ambiguous.
Thank you very much for your answer.
