How to reset counter value ?
LHerm.1
Hello everyone, i would like to know the HAL function that allows to reset the value of a simple counter. I don't find the HAL function to reset my counter to 0 before a next counting.
So all i want to do is to count, read my counter value and reput it to zero for the next count.
Thank for your help !
TIM2->CNT = 0;
There's probably a macro, try grep
6 REPLIES 6
Javier1
Principal
there is some info missing here. "counter" is ambiguous.
Are you reffering to the counter of a timer?
we dont need to firmware by ourselves, lets talk
TIM2->CNT = 0;
Yes sorry, it's the value of my timer.
I use a Nucleo board (F401RE) and i would like to know if a function "HAL_TIM_......" to reset the value of the counter to zero exists or not.
But the solution proposed by "Tesla Delorean" just behind works very well : TIMx ->CNT = 0;
It's not the most proper solution but it works.
Best regards
It works !
Thank very much
 * @brief Set the TIM Counter Register value on runtime.
 * @param __HANDLE__ TIM handle.
 * @param __COUNTER__ specifies the Counter register new value.
 * @retval None
#define __HAL_TIM_SET_COUNTER(__HANDLE__, __COUNTER__) ((__HANDLE__)->Instance->CNT = (__COUNTER__))
Andrew Neil
Evangelist III
