How to read CAN BUS with STM32F091RC + MCP2551 transreceiver?
‎2019-12-12 10:58 AM
Hi I am trying to read car CAN BUS with STM32F091RC + MCP2551 transreceiver. All I am getting is empty header and data. I guess my setup is incorrect, anyone can advice how to setup?
This is my setup:
CAN_TxHeaderTypeDef TxHeader;
CAN_RxHeaderTypeDef RxHeader;
uint8_t TxData[8];
uint8_t RxData[8];
uint32_t TxMailbox;
HAL_CAN_Start(&hcan);
/* Infinite loop */
/* USER CODE BEGIN WHILE */
while (1)
/* USER CODE END WHILE */
/* Get RX message */
if (HAL_CAN_GetRxMessage(&hcan, CAN_RX_FIFO0, &RxHeader, RxData) != HAL_OK)
/* Reception Error */
Error_Handler();
if (
RxData[0] != 0 ||
RxData[1] != 0 ||
RxData[2] != 0 ||
RxData[3] != 0 ||
RxData[4] != 0 ||
RxData[5] != 0 ||
RxData[6] != 0 ||
RxData[7] != 0 ||
RxHeader.DLC != 0 ||
RxHeader.ExtId != 0 ||
RxHeader.FilterMatchIndex != 0 ||
RxHeader.IDE != 0 ||
RxHeader.RTR != 0 ||
RxHeader.StdId != 0 ||
RxHeader.Timestamp != 0
BSP_LED_On(LED2);
- Labels:
CAN
STM32F0 Series
‎2019-12-14 6:29 AM
>>Any help?
Unfortunately multiple degrees of separation in terms of chips, tools, and libraries.
Suspect you'll need to search/grep the library source to understand specifically what is not liked in your parameters, presumably clocks, quanta, or other combination of thing that the library determines to be internally inconsistent.
‎2019-12-13 12:21 PM
Any help? I am reading can and getting all zeros when connected to car CAN bus. Why could I get zeroes?
I have connected transreceviver to PB8 and PB9.
‎2019-12-14 3:16 AM
‎2019-12-14 4:07 AM
#define HAL_CAN_ERROR_PARAM (0x00200000U) /*!< Parameter error
As I understand I am getting this error. What does this error mean and how to fix it?
‎2019-12-14 6:29 AM
>>Any help?
‎2019-12-14 2:36 PM
It started working!
I have calculated correct quantas by this video:
https://www.youtube.com/watch?v=rpE5UvQDcy4&list=PLERTijJOmYrApVZqiI6gtA8hr1_6QS-cs&index=14
Does power source matter? Can each CAN node be on different power source? Also different power source for transceiver?
Power source does not matter?
‎2022-04-26 8:11 AM
This file is not available on GitHub. Do you still have the files available?
