how to g
Jessy J
25 REPLIES 25
Posted on May 28, 2018 at 14:23
Try this:
struct fs_file file;
recv_err = fs_open(&file,'/STM32F4xx_files/ST.gif');
-- pa
Jessy J
Posted on May 28, 2018 at 16:30
here all the code for the http server based on netconn
* @brief serve tcp connection
* @param conn: pointer on connection structure
* @retval None
void http_server_serve(struct netconn *conn)
struct netbuf *inbuf;
err_t recv_err;
char* buf;
u16_t buflen;
struct fs_file * file;
/* Read the data from the port, blocking if nothing yet there.
We assume the request (the part we care about) is in one netbuf */
recv_err = netconn_recv(conn, &inbuf);
if (recv_err == ERR_OK)
if (netconn_err(conn) == ERR_OK)
netbuf_data(inbuf, (void**)&buf, &buflen);
/* Is this an HTTP GET command? (only check the first 5 chars, since
there are other formats for GET, and we're keeping it very simple )*/
if ((buflen >=5) && (strncmp(buf, 'GET /', 5) == 0))
/* Check if request to get ST.gif */
if (strncmp((char const *)buf,'GET /STM32F4xx_files/ST.gif',27)==0)
recv_err = fs_open(file,'/STM32F4xx_files/ST.gif');
netconn_write(conn, (const unsigned char*)(file->data), (size_t)file->len, NETCONN_NOCOPY);
fs_close(file);
/* Check if request to get stm32.jpeg */
else if (strncmp((char const *)buf,'GET /STM32F4xx_files/stm32.jpg',30)==0)
recv_err = fs_open(file,'/STM32F4xx_files/stm32.jpg');
fs_close(file);
else if (strncmp((char const *)buf,'GET /STM32F4xx_files/logo.jpg', 29) == 0)
/* Check if request to get ST logo.jpg */
recv_err = fs_open(file,'/STM32F4xx_files/logo.jpg');
fs_close(file);
else if(strncmp(buf, 'GET /STM32F4xxTASKS.html', 24) == 0)
/* Load dynamic page */
DynWebPage(conn);
else if((strncmp(buf, 'GET /STM32F4xx.html', 19) == 0)||(strncmp(buf, 'GET / ', 6) == 0))
/* Load STM32F4x7 page */
recv_err = fs_open(file,'/STM32F4xx.html');
fs_close(file);
else
/* Load Error page */
recv_err = fs_open(file,'/404.html');
fs_close(file);
/* Close the connection (server closes in HTTP) */
netconn_close(conn);
/* Delete the buffer (netconn_recv gives us ownership,
so we have to make sure to deallocate the buffer) */
netbuf_delete(inbuf);
* @brief http server thread
* @param arg: pointer on argument(not used here)
* @retval None
static void http_server_netconn_thread(void *arg)
struct netconn *conn, *newconn;
err_t err, accept_err;
/* Create a new TCP connection handle */
conn = netconn_new(NETCONN_TCP);
if (conn!= NULL)
/* Bind to port 80 (HTTP) with default IP address */
err = netconn_bind(conn, NULL, 80);
if (err == ERR_OK)
/* Put the connection into LISTEN state */
netconn_listen(conn);
while(1)
/* accept any incoming connection */
accept_err = netconn_accept(conn, &newconn);
if(accept_err == ERR_OK)
/* serve connection */
http_server_serve(newconn);
/* delete connection */
netconn_delete(newconn);
* @brief Initialize the HTTP server (start its thread)
* @param none
* @retval None
void http_server_netconn_init(void)
sys_thread_new('HTTP', http_server_netconn_thread, NULL, DEFAULT_THREAD_STACKSIZE, osPriorityAboveNormal);
Posted on May 28, 2018 at 14:56
It means it wants a pointer, and you provided a pointer to a pointer, ie the address of a pointer rather the address of a structure
If a function wants ptr, don't use &ptr
Posted on May 28, 2018 at 15:38
fichier != file, and the file pointer needs to actually point to some physical memory
Posted on May 28, 2018 at 16:06
The compiler is usually right, so if it is complaining something is wrong. Showing me two lines that haven't been cut-n-pasted from the failing code correctly doesn't help me diagnose the issue.
The 'file' pointer ultimately needs to point at some memory that describes some 'struct fs_file'
struct fs_file foofile;
struct fs_file *file = &foofile;
recv_err = fs_open ( file, '/STM32F4xx_files/ST.gif');
Posted on May 29, 2018 at 14:44
Per examples, you're supposed to be passing a pointer to a pointer so that fs_open can fill that pointer with a 'handle' to it's own structure.
See STM32Cube_FW_F7_V1.9.0\Projects\STM32746G-Discovery\Applications\LwIP\LwIP_HTTP_Server_Netconn_RTOS\Src\httpserver-netconn.c (or equivalent)
  * @retval None
static void http_server_serve(struct netconn *conn)
  err_t recv_err;
  char* buf;
  u16_t buflen;
        if (strncmp((char const *)buf,'GET /STM32F7xx_files/ST.gif',27)==0)
          fs_open(&file, '/STM32F7xx_files/ST.gif');
          netconn_write(conn, (const unsigned char*)(file.data), (size_t)file.len, NETCONN_NOCOPY);
          fs_close(&file);
        else if (strncmp((char const *)buf,'GET /STM32F7xx_files/stm32.jpg',30)==0)
          fs_open(&file, '/STM32F7xx_files/stm32.jpg');
          fs_close(&file);
