2019-06-27 07:53 AM
I am reading a burst of data 3072 half words from slave SPI device.
The Slave device requires NSS to be released after each half word transmission.
When I loop on HAL_SPI_TransmitReceive() function with size =1 for 3072 times it's OK.
but when I try to do it in one shoot using Size() with size = 3072 , the NSS is set low for the whole 3072.
the same happens when I try to use DMA "SPI NSS is low during the whole time of the 3072 half words".
I set NSSPMode = SPI_NSS_PULSE_ENABLE;
Here's my SPI Initialization tag.
hspi4.Instance = SPI4;
hspi4.Init.Mode = SPI_MODE_MASTER;
hspi4.Init.Direction = SPI_DIRECTION_2LINES;
hspi4.Init.DataSize = SPI_DATASIZE_16BIT;
hspi4.Init.CLKPolarity = SPI_POLARITY_LOW;
hspi4.Init.CLKPhase = SPI_PHASE_1EDGE;
hspi4.Init.NSS = SPI_NSS_HARD_OUTPUT;
hspi4.Init.BaudRatePrescaler = SPI_BAUDRATEPRESCALER_8;
hspi4.Init.FirstBit = SPI_FIRSTBIT_MSB;
hspi4.Init.TIMode = SPI_TIMODE_DISABLE;
hspi4.Init.CRCCalculation = SPI_CRCCALCULATION_DISABLE;
hspi4.Init.CRCPolynomial = 0x0;
hspi4.Init.NSSPMode = SPI_NSS_PULSE_ENABLE;
hspi4.Init.NSSPolarity = SPI_NSS_POLARITY_LOW;
hspi4.Init.FifoThreshold = SPI_FIFO_THRESHOLD_01DATA;
hspi4.Init.TxCRCInitializationPattern = SPI_CRC_INITIALIZATION_ALL_ZERO_PATTERN;
hspi4.Init.RxCRCInitializationPattern = SPI_CRC_INITIALIZATION_ALL_ZERO_PATTERN;
hspi4.Init.MasterSSIdleness = SPI_MASTER_SS_IDLENESS_00CYCLE;
hspi4.Init.MasterInterDataIdleness = SPI_MASTER_INTERDATA_IDLENESS_00CYCLE;
hspi4.Init.MasterReceiverAutoSusp = SPI_MASTER_RX_AUTOSUSP_DISABLE;
hspi4.Init.MasterKeepIOState = SPI_MASTER_KEEP_IO_STATE_ENABLE;
hspi4.Init.IOSwap = SPI_IO_SWAP_DISABLE;
if (HAL_SPI_Init(&hspi4) != HAL_OK)
Error_Handler();
How can I generate pulse on NSS after each half word if I am reading the whole data in one shot or using DMA?
In the next picture NSS in Yellow and SCK in green, this is the required pattern, I get it when sending data one by one
and in the next picture 1st half word is sent in one command and after that I start DMA,
you can see that NSS is kept low during the whole data transmission
Best Regards
Hossam Alzomor
2019-06-28 01:30 AM
thanks @Community member
it was the MIDI, I should use a value greater than 1
Here's the working configurations
hspi4.Init.MasterInterDataIdleness = SPI_MASTER_INTERDATA_IDLENESS_02CYCLE;
Hossam Alzomor
2019-06-27 08:54 AM
Set nonzero SPI_CFG2.MIDI, read Slave select (SS) pin management subchapter of the SPI chapter in RM.
2019-06-28 01:30 AM
Hossam Alzomor
