2017-06-02 08:09 AM
Hi Dears
I use STM32F405 as MicroController and I have some problem in hardware.
For example i design a circuit with STM32F405 and i supplied it with HI-LINK power supply module.
When I connect some devices into a power outlet ? microcontroller does unwanted things but it dosent RESET.
I putted some filters that contain capacitors and inductors.
I changed my clock source and i reduced the system core clock
I use 16 MHZ oscillator to increase stability.
But the problem is not resolved.
so
How can i resolve this problem???????????
thank you
#filter #stm32-power-suplly-filter #power-supply-filter #stm32-power-supply2017-06-02 08:46 AM
The response requires an electrical circuit of the device, and a block program structure (draw cubes).
Psychics on vacation.2017-06-03 01:14 AM
1. Which hi-link module? I just have some of them.
2. If you simply use a power supply directly to MCU, does it work?
3. check Reset pin
4. make sure the mcu is still alive.
