How to debug program from SRAM
Options
‎2013-06-03 1:21 AM
Posted on June 03, 2013 at 10:21
Edit: Forumsoftware doesn´t work on mobile devices
2 REPLIES 2
Options
‎2013-06-03 4:20 AM
Posted on June 03, 2013 at 13:20
Pretty much the same way you do for any other address range, you modify the linker and debugging scripts as required by the architecture and tools.
Options
‎2013-06-03 1:23 PM
Posted on June 03, 2013 at 22:23
Hi
Sorry, I thought I wrote a short text in my priveous post, but obviously I submitted it uncorrectly. I'm working with ARM Keil and uVision IDE, there I set up the SRAM as the target location in the file options. Is that the correct method to do this? Another question: Then configuring the ST-Link, must I enter as Flash address the address of the SRAM or are some more settings required ? Regards Jannis
