How do I perform this function shorter ?
kemal
Posted on April 17, 2015 at 12:43
unsigned long a;
void assign(unsigned int a1,unsigned int a2)
        if (a2==1)
    a =1;
         if (a2==2)
    a =2;
         if (a2==4)
    a =4;
         if (a2==8)
    a =8;
         if (a2==16)
    a =16;
        if (a2==32)
    a =32;
         if (a2==64)
    a =64;
         if (a2==128)
    a =128;
         if (a2==256)
    a =256;
         if (a2==512)
    a =512;
        if (a2==1024)
    a =1024;
         if (a2==2048)
    a =2048;
         if (a2==4096)
    a =4096;
         if (a2==8192)
    a =8192;
         if (a2==16384)
    a =16384;
        if (a2==32768)
    a =32768;
        if (a1==1)
    a =65536;
         if (a1==2)
    a =131072;
         if (a1==4)
    a =262144;
         if (a1==8)
    a =524288;
         if (a1==16)
    a =1048576;
        if (a1==32)
    a =2097152;
         if (a1==64)
    a =4194304;
         if (a1==128)
    a =8388608;
         if (a1==256)
    a =16777216;
         if (a1==512)
    a =33554432;
        if (a1==1024)
    a =67108864;
         if (a1==2048)
    a =134217728;
         if (a1==4096)
    a =268435456;
         if (a1==8192)
    a =536870912;
         if (a1==16384)
    a =1073741824;
        if (a1==32768)
    a =2147483648;
3 REPLIES 3
Posted on April 17, 2015 at 13:17
if (a2 <= 32768 && ((a2 == 1) || ((((a2 - 1) << 1) & a2) == a2))) a = a2;
if (a1 <= 32768 && ((a1 == 1) || ((((a1 - 1) << 1) & a1) == a1))) a = (long)a1 << 16;
Posted on April 17, 2015 at 13:26
Use else to eliminate pointless comparisons or switch/case?
Understand the purpose, and desired function better?
kemal
Posted on April 17, 2015 at 14:20
This code
worked fine
1kb
was
my wife.
thanks
all
