Hide compiler message
vicvicvar
Hi all,
Is there a way to hide the console-terminated output message?Per the attached image
I need to remove specifically the timestamp
thanks
Guru
Pressing Remove Launch will remove the tab entirely. Probably no way to only remove the timestamp. Why do you need to remove it?
Guru
Thanks! I'm taking screenshots for a step by step bring-up and this information is uncesarry
