2021-01-27 01:14 AM
2021-01-27 02:24 AM
Same way you'd interface anything to anything else:
2021-01-27 03:32 AM
Hi Andrew,
Thanks for the information.
Kindly help me out in below query,
We have D/CX pin along with above pins in LCD. ((D/CX): This pin is used to select “Data or Command�? in the parallel interface).
Can we connect GPIO to D/CX pin, or do we have any dedicated pin in FSMC interface?
2021-01-27 03:59 AM
Per the link, you need to study the documentation to work that out.
You titled this thread, "8080-MCU" - did you really mean that? Looks like you're talking about an LCD - not an MCU?
