2023-05-22 6:17 AM
I would like to do this to control LED strips, however, I have a problem because no matter how hard I try using the HAL_I2C_Master, it doesn't work.
2023-05-26 2:15 AM
Hello @HGanc.1 ,
First, make sure that you are using the correct address and the correct frequency for the I²C communication.
The take an oscilloscope to check the I2C_SDA and I2C_SCL behavior.
Foued
