Hard Fault detected
‎2024-05-15 5:04 AM
Hi
I am using STM32U575ZIT6 microcontroller. I have created a simple program that turns on several LEDs on the board, but when switching to the non-secure zone, a Hard Fault occurs.
- Labels:
STM32U5 series
‎2024-05-15 6:06 AM - edited ‎2024-05-15 6:06 AM
Hi @Istillaga
Did you program secure or non-secure image first? It could be linked to the programming order.
‎2024-05-15 6:26 AM
Hi @FBL ,
I first programmed the non-secure image. Previously, I managed to get it to work with another program, but it doesn't work with this one. I followed the same steps and nothing. I also configured the option bytes to start from the appropriate addresses.
‎2024-05-16 12:47 AM
I also get the following message from the debugger: No source available for "<signal handler called>() at 0xffffffa9".
Running a blank program also gives the error, so I suppose it might be some configuration of the option bytes.
