2020-04-09 12:45 PM
2020-04-09 12:52 PM
Good luck with that. Thats the TOF sensor with the whole API included in the demo package. Give up on that as well
2020-04-09 1:49 PM
Ouch, I've never had to build a program so complex it took three entire days to code and test.
It might help if you explained the problem and what you've tried in the way of debugging.
Jack Peacock
2020-08-14 7:09 AM
did you manage to do it?
2020-08-18 12:28 AM
The API is sub-par... Only the documentation is worse...
