FTDI with Nucleo-L053R8
‎2015-09-17 01:15 AM
I'm using Nucleo-L053R8 for my project. I have connected external 3-axis sensor to the nucleo board. And it's working fine. Now I'm looking to make custom board. I connected FT232 with USB to the pins TX and RX and taken out jumpers on CN2. I have installed drivers for RS232. But i could not see the output on serial terminal. Can someone tell me the mistake?. Should i need to make any other connections?. Should i program the USB?- Mark as New
‎2015-09-17 02:25 AM
Disconnect the FTDI from the mcu, short Rx with Tx - do you see characters echoed in terminal?
No go? - is in the terminal handshake set in some way? Play with it. If you get this working, disconnect the short, connect it back to mcu - which pin connected to which? JW- Mark as New
‎2015-09-17 04:15 AM
Thanks for your reply. I disconnected with MCU and shorted both RXD and TXD but nothing on teraterm serial terminal. Later on i tried with RX-1 and TX-0 but nothing. ________________ Attachments : FTDI.JPG : https://st--c.eu10.content.force.com/sfc/dist/version/download/?oid=00Db0000000YtG6&ids=0680X000006I1DN&d=%2Fa%2F0X0000000bjy%2F5Is4o5klHI.0_sZkZ6KzVrjs0QijgEg_.IWu0iod8RY&asPdf=false- Mark as New
‎2015-09-17 04:41 AM
Please look into the pics
________________ Attachments : IMG_3718.JPG : https://st--c.eu10.content.force.com/sfc/dist/version/download/?oid=00Db0000000YtG6&ids=0680X000006I1DI&d=%2Fa%2F0X0000000bjx%2FvxmM36brJaZOFvWyhRCGvK8H7cbKTdqjL81EUS4eG2g&asPdf=false- Mark as New
‎2015-09-17 05:43 AM
Ok, but what is wired to what? Describe the pin connections, or provide a schematic.
You may need to cross over the sense of RX/TX. In both cases the TX pin is likely the output.Up vote any posts that you find helpful, it shows what's working..
‎2015-09-17 06:25 AM
I have connected TXD pin from FTDI to RX pin in nucleo. And RXD from FTDI to TX from nucleo. Then i pressed restart. But i could not see any output on serial terminal ( teraterm).
I also tried connecting RX-1 and TX-0 to nucleo TX and RX respectively.
‎2015-09-17 07:28 AM
There's no reason to proceed and connect the FTDI to the mcu until you get this going. Try a different terminal. Are you sure you know the FTDI's virtual serial number? Have you observed it in Device Manager (I assume you are under Windows, I am not familiar with Linux working of FTDI devices)? JW- Mark as New
‎2015-09-17 07:31 AM
‎2015-09-18 03:08 AM
Its working. On the nucleos, D0 & D1 are not connected to the microcontroller's serial 2 Tx/Rx !
use serial 1 Tx & Rx on (D8 or D10) & D2.
‎2015-09-18 05:28 AM
Ok, but aren't there solder-bridges that can connect them, and the PA2/PA3 USART2 pins are connected the the ST-LINK's VCP connection
