Flash Download failed - Could not load file .axf
‎2023-03-06 6:30 AM
Hi! I am working on a project using a STM32f407 board, I wrote the code but when I try to load it, an error shows. I saw a similar problem but the solutions didnt work for me. Here is the build output
STM32F4 Series
‎2023-03-08 4:00 AM
Then try to select compiler v.6. If this won't help, the Keil support is here.
‎2023-03-07 12:43 AM
Hello @LimoGr​
You may need to check this thread. Try Options-> C/C++ -> Preprocessor Symbols then Define: Enter USE_STDPERIPH_DRIVER instead of USE_STDPERIPH_dRIVER, STM32F4XX, HSE_VELUE=8000000.
Does this answer your question?
‎2023-03-07 5:26 AM
Hi! I actually tried that but it didnt work because I think the problem here is in the compiler as the build output says target 'keil_tx' uses ARM-Compiler 'Default Compiler Version 5' which is not available. But I do not understand what should I do
‎2023-03-07 5:34 AM
Pick a compiler that IS available, or perhaps reinstall Keil properly?
Did it install Version 6, or were you trying to use the GNU/GCC compilers?
You can't download the .AXF because the build did not complete.
‎2023-03-07 5:38 AM
Indeed, you may need to change the missing compiler. Try to change default ARM compiler version and see if it works.
‎2023-03-08 1:01 AM
Keil was installed properly, the issue was with the compiler and as I said I am a beginner and only getting familiar with this software. the solution is here :
https://www.youtube.com/watch?v=u5SrhXUHYu4&ab_channel=EasyElectric
‎2023-03-08 4:00 AM
‎2023-03-08 4:22 AM
Thank you! It is working perfectly!
