Failure when Configuring UART2 in the STM32C031C6
tpeng.1
When configuring UART2 in the STM32C0316-DK, the emulator is locked.
Error in executing 'step' command ...
Target is not responding, retrying...
Code is running here (stm32c0xx_hal_msp.c line 272):
  /**USART2 GPIO Configuration
  PA8   ------> USART2_TX
  PA13   ------> USART2_RX
  GPIO_InitStruct.Pin = GPIO_PIN_8;
  GPIO_InitStruct.Alternate = GPIO_AF1_USART2;
  GPIO_InitStruct.Pin = GPIO_PIN_13;
  GPIO_InitStruct.Alternate = GPIO_AF4_USART2;
Need you help.
Tim
Jaroslav JANOS
Hello @tpeng.1​ ,
this is quite common mistake, you reconfigured one of your pins used for debug (PA13). You should use other pins for the USART2, when you want to use SWD.
BR,
Jaroslav
2 REPLIES 2
Jaroslav JANOS
Hello @tpeng.1​ ,
BR,
Jaroslav
Hi Jaroslav,
Thank you very much for your quick response!
Now I understand that PA13 is used for debug.
Br,
Tim
