‎2020-12-08 01:56 AM
Hi everyone .
I'm looking for a demo code to run the SD card (16gb) with FatFs on the STM32H757 i-EVAL Board.
When I generate it with CubeMx the demonstration doesn't work (I didn't forget to activate the transiver)
Thanks you =)
‎2020-12-08 04:16 AM
‎2020-12-08 02:31 AM
Hi Tteva.1,
Can you please share your .ioc file ?
Else, you can refer to the STM32CubeH7 Firmware. You can find examples and applications that can help you.
Best Regards,
Ons.
‎2020-12-08 05:28 AM
‎2021-09-25 12:33 PM
Hi Tteva.1,
I want generate code with CubeMx for sdmmc1 on STM32H757i- EVAL but it doesn't work ... i used stm32h747.c lib and i also tried to change example of stm32h743- eval (sd_read_write_HS_dma) but it doesn't work...
I'm really confused about ...
do you find any solution for it??
Best Regards,
amir.
