error: array type has incomplete element type
GreenGuy
Lead
Posted on March 30, 2018 at 07:29
This is occurring in fsdata_custom.c in the LwIP_HTTP_Server_Netconn_RTOS project I imported from CubeMX.  The struct that is being referenced is :
struct fsdata_file {
  const struct fsdata_file *next;
  const unsigned char *name;
  const unsigned char *data;
  int len;
  u8_t flags;
#if HTTPD_PRECALCULATED_CHECKSUM
  u16_t chksum_count;
  const struct fsdata_chksum *chksum;
#endif /* HTTPD_PRECALCULATED_CHECKSUM */
and the HTTPD_PRECALCULATED_CHECKSUM is defined as 0.
Where the error is occurring in fsdata_custom.c is at: (line 2336
const struct fsdata_file file__STM32F7xx_files_logo_jpg[] = { {
file_NULL,
data__STM32F7xx_files_logo_jpg,
data__STM32F7xx_files_logo_jpg + 28,
sizeof(data__STM32F7xx_files_logo_jpg) - 28,
1,
According to the struct definition it looks like all the elements are there so I am confused.
Anyone run across this?
Ben S
Posted on June 28, 2018 at 07:00
In case anyone else comes across this - fsdata_custom.c isn't meant to be directly compiled, it gets included in httpd/fs.c.  I removed fsdata_custom.c from my Makefile and the errors went away
5 REPLIES 5
Ben S
Posted on June 27, 2018 at 20:31
hey greg - did you ever find a solution to this?  I'm having the same problem and can't seem to figure it out
Ben S
Posted on June 28, 2018 at 19:07
Ben, sorry for the late reply.  Yes you got it right.  For me I simply excluded the file from the build in the IDE.
BROBL
Hello Guys,
I'm having the same problem when trying to build the example; my problem don't go away when I exclude that file from the build, I mean is replaced by a ..\Middlewares\Third_Party\LwIP\src\apps\httpd\fs.c:41:27: fatal error: fsdata_custom.c: No such file or directory
 #[include "fsdata_custom.c"]​
Don't know if you would have any ideas
Jona
I was able to get rid of the errors by including the fsdata.h file. But eventually just excluded fsdata_custom.c. I then ended up with 3 more fatal errors
multiple definition of _isatty
(2)Undefined reference to "missing_USE_FREERTOS_macro"
It must be nearly IMPOSSIBLE for St to create examples that actually build and work as I have yet to see one.
Adding "USE_FREERTOS" to the Project Properties solved one. But still have no solution for _isatty. Searching for it.. doesn't show up anywhere.
