This widget could not be displayed.
DMA I2S not working (STM32H723)!!!!
LLavr.1
I tried everything but keep on running on the same issue:
0693W00000FC9HAQA1.pngIn the reference manual it describe the DMA for the I2S, so I'm quite sure it is possible to enable it.
Please help me.
CPINA
Indeed, It is the latest version. I am facing the same issue than yours. DMA is for sure usable even for the half duplex mode.
I am going to see to rise up this issue.
In between, you can set-up the DMA like described in SPI HAL library examples embedded into the STM32H7 firmware library.
BR,
Christophe
7 REPLIES 7
CPINA
Which is the version of CUBEMX you have in your own ? Is it the latest ?
BR,
Christophe
LLavr.1
It is the 6.3.0. It should be the latest.
CPINA
BR,
Christophe
CPINA
I add confirmation that this point had already been highlighted and analyzed with a validated fix forcasted for next revision 6.4 of CUBEMX.
BR,
Christophe
LLavr.1
Thank you for the reply.
I hope the new release will be updated soon.
Best Regards,
Luigi Lavriani
You are more than welcome.
Best regards,
Christophe
Is the update release date already known? I'm having the same problem...
