CMSIS-DSP with STM32F302
ermes
Dear all,
is it possible to use CMSIS-DSP with STM32F302XXX?
Actually I'm working with NUCLEO STM32F302R8Tx (but final board will have STM32F302RCT6) and I have two issues :
1) I am not able to find lib *.a in repository CMSIS_DSP
2) Following this guide Guide I get this error ../Drivers/CMSIS/Include/core_cm4.h:105:8: error: #error "Compiler generates FPU instructions for a device without an FPU (check __FPU_PRESENT)"
Is there some hardware limitation?
Or am I missing some step?
Thank you
Well, the STM32F302R8 does have an FPU - so there must be a problem in your configuration:
https://www.st.com/en/microcontrollers-microprocessors/stm32f302r8.html#:~:text=embedding%20a%20floating%20point%20unit%20(FPU)
Have you tried a search of the forum?
https://community.st.com/t5/forums/searchpage/tab/message?q=cmsis%20dsp%20stm32f3&noSynonym=false&collapse_discussion=true
https://community.st.com/t5/forums/searchpage/tab/message?advanced=false&allow_punctuation=false&q=cmsis%20dsp
SofLit
As stated by @Andrew Neil  STM32F302 has a HW FPU.
Check out the DSP demo provided in X-CUBE-DSPDEMO (STM32F429I-Discovery project) which you can inspire from.
PS:
