clock setting, STM32H750
‎2023-01-10 6:42 AM
I have two different clock setting and only one of them works - but I have no idea why?
The only difference is the PLLM and PLLN value:
RCC_OscInitStruct.PLL.PLLM = 25; // 5 NOT OK
RCC_OscInitStruct.PLL.PLLN = 432; // 160 NOT OK
Would appreciate any hints...
See clock seting below, I have a 25MHz ext. Crystal:
NOT working clock setting:
CC_ClkInitTypeDef RCC_ClkInitStruct;
RCC_OscInitTypeDef RCC_OscInitStruct;
HAL_StatusTypeDef ret = HAL_OK;
/*!< Supply configuration update enable */
HAL_PWREx_ConfigSupply(PWR_LDO_SUPPLY); /* PWR set to LDO for the STM32H750B-DISCO board */
/* The voltage scaling allows optimizing the power consumption when the device is
clocked below the maximum system frequency, to update the voltage scaling value
regarding system frequency refer to product datasheet. */
__HAL_PWR_VOLTAGESCALING_CONFIG(PWR_REGULATOR_VOLTAGE_SCALE1);
while(!__HAL_PWR_GET_FLAG(PWR_FLAG_VOSRDY)) {}
/* Enable HSE Oscillator and activate PLL with HSE as source */
RCC_OscInitStruct.OscillatorType = RCC_OSCILLATORTYPE_HSE;
RCC_OscInitStruct.HSEState = RCC_HSE_ON;
RCC_OscInitStruct.HSIState = RCC_HSI_OFF;
RCC_OscInitStruct.CSIState = RCC_CSI_OFF;
RCC_OscInitStruct.PLL.PLLSource = RCC_PLLSOURCE_HSE;
RCC_OscInitStruct.PLL.PLLM = 5;
RCC_OscInitStruct.PLL.PLLN = 160;
RCC_OscInitStruct.PLL.PLLFRACN = 0;
RCC_OscInitStruct.PLL.PLLP = 2;
RCC_OscInitStruct.PLL.PLLR = 2;
RCC_OscInitStruct.PLL.PLLQ = 4;
RCC_OscInitStruct.PLL.PLLVCOSEL = RCC_PLL1VCOWIDE;
RCC_OscInitStruct.PLL.PLLRGE = RCC_PLL1VCIRANGE_2;
ret = HAL_RCC_OscConfig(&RCC_OscInitStruct);
if(ret != HAL_OK)
Error_Handler();
/* Select PLL as system clock source and configure bus clocks dividers */
RCC_ClkInitStruct.ClockType = (RCC_CLOCKTYPE_SYSCLK | RCC_CLOCKTYPE_HCLK | RCC_CLOCKTYPE_D1PCLK1 | RCC_CLOCKTYPE_PCLK1 | \
RCC_CLOCKTYPE_PCLK2 | RCC_CLOCKTYPE_D3PCLK1);
RCC_ClkInitStruct.SYSCLKDivider = RCC_SYSCLK_DIV1;
RCC_ClkInitStruct.AHBCLKDivider = RCC_HCLK_DIV2;
RCC_ClkInitStruct.APB3CLKDivider = RCC_APB3_DIV2;
RCC_ClkInitStruct.APB1CLKDivider = RCC_APB1_DIV2;
RCC_ClkInitStruct.APB2CLKDivider = RCC_APB2_DIV2;
RCC_ClkInitStruct.APB4CLKDivider = RCC_APB4_DIV2;
ret = HAL_RCC_ClockConfig(&RCC_ClkInitStruct, FLASH_LATENCY_4);
if(ret != HAL_OK)
Error_Handler();
Working clock setting:
if(ret != HAL_OK)
Error_Handler();
if(ret != HAL_OK)
Error_Handler();
RCC
STM32H7 Series
‎2023-01-16 2:47 AM
> Well, I don't see anything blinking with 600 ms in any video.
These videos shows the debug mode, below two video links with normal mode
> But you see that the "working version" runs on a 216 MHz clock, the other version with 400 MHz ?
Yes
> Try to verify your PCB .
Phuu, it's a 6-layer, made by a freelancer... where would you start? Measure the clock frequency?
Here the video in normal mode with 5/160 clock setting (D1CPRE = 400 MHz):
https://drive.google.com/file/d/1bgKju-XdIOGF8OOVtqfoF6AWtfhtE2Dg/view?usp=share_link
Here the video in normal mode with 25/432 clock setting (D1CPRE = 216 MHz):
https://drive.google.com/file/d/1bXV0G1ygs-yc_txlSVRaHcNR-42bdoNI/view?usp=share_link
‎2023-01-16 4:37 AM
It looks GPIO PF10 is not compatible with clock setting 5/160 (400 MHz)...
GPIO PF10 = blue LED, GPIO PC13 = red LED
Can this be logical?
EDIT: If reduce the frequency from 400 MHz to 300Mhz or lower, the blue LED is slightly visible..
I will measure this GPIO output, strange...
Result: The higher the frequency, the lower the GPIO output voltage... special.
And because the blue LED needs more VF, I see the problem first with the blue LED...
Additional note: I use the STLink/V2 supply (Pin 19)... maybe this is the problem (I thought the supply is rated up to 800mA).
- « Previous
- 1
- 2
- Next »
