Change ADC clock in STM32H7
‎2023-03-23 2:46 AM
Hello, i'm using an STM32H7 but unfortunately for a known bug of the firmware package i'm not able to select the ADC prescaler. Uprading to a newer firmware package is not considered.
At the moment i resolved applying a prescaler with the line
hadc1.Init.ClockPrescaler = ADC_CLOCK_SYNC_PCLK_DIV1;
The problem is that this only works with the synchronous clock, if i try the asynchronous clock the ADC doesn't work, like if the clock is not enabled.
My idea is that i have to enable PLL2P because is disabled, how can i do it with code since i'm not able to manage it througth cube ide?
Thank you in advice
ADC
STM32H7 series
‎2023-03-23 3:06 AM
Find SystemClock_Config() and modify.
Here's some clock setup for a Nucleo H723, including ADC from PLL3:
But better check the values for your application.
* @brief System Clock Configuration
* @retval None
/* notes:
* Power:
* - voltage scaling for core:
* VOS0 ~1.36 V - "boosted performance" - highest freq -> highest power
* VOS1 ~1.21 V - "high performance"
* VOS2 ~1.10 V - "medium performance"
* -> in these voltage ranges SAI, I2S, OctoSPI can work with at least up to
* 113 MHz (RM0468, pg 336)
* PLLs:
* - main PLL input range: 2 .. 16 MHz
* - PLL2 & 3 input range: 1 .. 2 MHz
void SystemClock_Config(void)
RCC_OscInitTypeDef RCC_OscInitStruct = { 0 };
RCC_ClkInitTypeDef RCC_ClkInitStruct = { 0 };
/* supply configuration update enable */
HAL_PWREx_ConfigSupply(PWR_LDO_SUPPLY);
/* configure the main internal regulator output voltage */
__HAL_PWR_VOLTAGESCALING_CONFIG(PWR_REGULATOR_VOLTAGE_SCALE1);
while( 0 == __HAL_PWR_GET_FLAG(PWR_FLAG_VOSRDY) );
/* configure LSE Drive Capability */
HAL_PWR_EnableBkUpAccess();
__HAL_RCC_LSEDRIVE_CONFIG(RCC_LSEDRIVE_LOW);
/* Macro to configure the PLL clock source */
__HAL_RCC_PLL_PLLSOURCE_CONFIG(RCC_PLLSOURCE_HSE);
/* initialize RCC oscillators and PLL 1 for core and peripheral busses
RCC_OscInitStruct.OscillatorType = RCC_OSCILLATORTYPE_HSE | RCC_OSCILLATORTYPE_LSE;
RCC_OscInitStruct.HSEState = RCC_HSE_BYPASS;
RCC_OscInitStruct.LSEState = RCC_LSE_ON;
RCC_OscInitStruct.PLL.PLLSource = RCC_PLLSOURCE_HSE;
/* NUCLEO_H723: 8.333 MHz input from ST-LINK */
RCC_OscInitStruct.PLL.PLLM = 4; /* -> 8 MHz / 4 = 2 MHz */
RCC_OscInitStruct.PLL.PLLN = 192; /* -> 400 MHz */
RCC_OscInitStruct.PLL.PLLP = 1; /* 400 MHz */
RCC_OscInitStruct.PLL.PLLQ = 5; /* 80 MHz for FDCAN */
RCC_OscInitStruct.PLL.PLLR = 4; /* 100 MHz */
RCC_OscInitStruct.PLL.PLLRGE = RCC_PLL1VCIRANGE_1;
RCC_OscInitStruct.PLL.PLLVCOSEL = RCC_PLL1VCOWIDE;
RCC_OscInitStruct.PLL.PLLFRACN = 0;
if( HAL_RCC_OscConfig(&RCC_OscInitStruct) != HAL_OK ) Error_Handler();
RCC_ClkInitStruct.ClockType = RCC_CLOCKTYPE_HCLK | RCC_CLOCKTYPE_SYSCLK
| RCC_CLOCKTYPE_PCLK1 | RCC_CLOCKTYPE_PCLK2
| RCC_CLOCKTYPE_D3PCLK1 | RCC_CLOCKTYPE_D1PCLK1;
RCC_ClkInitStruct.SYSCLKDivider = RCC_SYSCLK_DIV1;
RCC_ClkInitStruct.AHBCLKDivider = RCC_HCLK_DIV2;
RCC_ClkInitStruct.APB1CLKDivider = RCC_APB1_DIV2;
RCC_ClkInitStruct.APB2CLKDivider = RCC_APB2_DIV2;
RCC_ClkInitStruct.APB3CLKDivider = RCC_APB3_DIV2;
RCC_ClkInitStruct.APB4CLKDivider = RCC_APB4_DIV2;
if( HAL_RCC_ClockConfig(&RCC_ClkInitStruct, FLASH_LATENCY_2) != HAL_OK ) Error_Handler();
* @brief Peripherals Common Clock Configuration
* @retval None
void PeriphCommonClock_Config(void)
RCC_PeriphCLKInitTypeDef PeriphClkInitStruct = { 0 };
/* PLL2: base for 400 kHz / x sampling rate */
PeriphClkInitStruct.PLL2.PLL2M = 2;
PeriphClkInitStruct.PLL2.PLL2N = 122;
PeriphClkInitStruct.PLL2.PLL2P = 5; /* 102.4 MHz */
PeriphClkInitStruct.PLL2.PLL2Q = 5; /* 102.4 MHz */
PeriphClkInitStruct.PLL2.PLL2R = 10; /* 51.2 MHz */
PeriphClkInitStruct.PLL2.PLL2RGE = RCC_PLL2VCIRANGE_2;
PeriphClkInitStruct.PLL2.PLL2VCOSEL = RCC_PLL2VCOWIDE;
PeriphClkInitStruct.PLL2.PLL2FRACN = PLL_FRACN_BASE_8M3_51M2;
/* PLL3: base for 192 kHz / x sampling rate */
PeriphClkInitStruct.PLL3.PLL3M = 5;
PeriphClkInitStruct.PLL3.PLL3N = 235;
PeriphClkInitStruct.PLL3.PLL3P = 4; /* 98.304 MHz */
PeriphClkInitStruct.PLL3.PLL3Q = 4; /* 98.304 MHz */
PeriphClkInitStruct.PLL3.PLL3R = 8; /* 49.152 MHz */
PeriphClkInitStruct.PLL3.PLL3RGE = RCC_PLL3VCIRANGE_0;
PeriphClkInitStruct.PLL3.PLL3VCOSEL = RCC_PLL3VCOMEDIUM;
PeriphClkInitStruct.PLL3.PLL3FRACN = PLL_FRACN_BASE_8M3_98M3;
/* SAI 1, SAI 4 */
PeriphClkInitStruct.PeriphClockSelection |= ( RCC_PERIPHCLK_SAI1 | RCC_PERIPHCLK_SAI4A | RCC_PERIPHCLK_SAI4B );
/* SPI 1, SPI 2, SPI 6 */
PeriphClkInitStruct.PeriphClockSelection |= ( RCC_PERIPHCLK_SPI1 | RCC_PERIPHCLK_SPI2 | RCC_PERIPHCLK_SPI6 );
PeriphClkInitStruct.Sai1ClockSelection = RCC_SAI1CLKSOURCE_PLL2;
PeriphClkInitStruct.Sai4AClockSelection = RCC_SAI4ACLKSOURCE_PLL2;
PeriphClkInitStruct.Spi123ClockSelection = RCC_SPI123CLKSOURCE_PLL2;
PeriphClkInitStruct.Spi6ClockSelection = RCC_SPI6CLKSOURCE_PLL2;
/* ADC */
PeriphClkInitStruct.PeriphClockSelection |= RCC_PERIPHCLK_ADC;
PeriphClkInitStruct.AdcClockSelection = RCC_ADCCLKSOURCE_PLL3;
if( HAL_RCCEx_PeriphCLKConfig(&PeriphClkInitStruct) != HAL_OK ) Error_Handler();
‎2023-03-23 3:06 AM
* @retval None
/* notes:
* Power:
* PLLs:
* @retval None
/* SAI 1, SAI 4 */
/* ADC */
‎2023-03-23 4:55 AM
‎2023-03-23 5:01 AM
Thank for your answer, very useful. The only question is that you told me to modify the SystemClock_Config(), but looking on your code seems like that the function that i need to modify is PeriphCommonClock_Config(), which i don't have. Is there a way to make it appear or do i need to write by hand and then call it?
‎2023-03-23 8:11 AM
Oops... okay, it's in RCC_PeriphCLKInitTypeDef ()
However you like, it's no big deal to integrate that into SystemClock_Config().
