Cannot Configure TIM3 , Timer count values are drifting ?
‎2022-05-14 7:20 AM
I'm using an STM32F401CCU6 microcontroller and am trying to generate a timer interrupt of 10 us with TIMER3.The timer is a update event timer. The formula I'm using is:
Update_event = TIx_CLK/((PSC + 1)*(ARR + 1))
Below, I've given my clock configuration. Secondly, I got my ARR = (840-1) and the Prescaler = (1-1) for a 10 µs timer. Is this incorrect?
Also, I'm using the Keil development software and when I run the code,my first query is the right psc and arr values . Secondly when ever interrupt is generated my timer values is different each time interrupt is generated , the counts are drifting ??.My Code :
void TIM3_Init(void)
__HAL_RCC_TIM3_CLK_ENABLE();
TIM3->SR &=~(TIM_CR1_CEN);
TIM3->CNT = 0 ;
TIM3->ARR = (839);
TIM3->PSC = (1-1) ;
TIM3->DIER |=TIM_DIER_UIE;
HAL_NVIC_SetPriority(TIM3_IRQn, 0, 0);
HAL_NVIC_EnableIRQ(TIM3_IRQn);
TIM3->CR1 |= TIM_CR1_CEN ; // First BreakPoint
TIM3Interrupt routine :
void TIM3_IRQHandler(void)
HAL_TIM_IRQHandler(&htim3); // Second Breakpoint
How I debug is by first placing breakpoint on my TIM3_Init function last line , Hit that breakpoint , Reset my Timer on the Keil IDE as t1 , and run until TIM3 Interrupt is generated and note the value , as I said , the values are drifting , first they are 14us , then .5us , I dont understand how difficult could it be to Initialize a timer , I've done it with stm32f103 series and never had a headache . Please tell me what Im doing wrong , could my RCC Clock be the problem which I doubt , or IDE settings. I've been fighting with this simple initialization for 3 days .
DEBUG
STM32F4 Series
TIM
‎2022-05-14 7:49 AM
TIM3->SR &=~(TIM_CR1_CEN); // NOT SR
Probably saturating if your code/call-back is doing too much. Try 10 KHz rather than 100 KHz
‎2022-05-14 10:11 AM
Do you freeze the timer during debugging, in DBGMCU_APB1_FZ? If not, the timer continues to run while your debugger stopped at the breakpoint.
Also, you should stop only if TIMx_SR.UIF is set, although the Cube code you are calling is probably inefficient enough to hide this problem.
‎2022-05-14 12:00 PM
Thankyou so much , the DBGMCU_APB1_FZ debugmode register did the job for me . Although Ive noticed that having exact theoretical timer register values are not neccsessry , could this be a problem in the future ?
‎2022-05-14 1:02 PM
I don't understand. Not necessary for what? And what do you mean by "exact theoretical timer register values"?
‎2022-05-14 11:19 PM
@Community member​ for example my clock speed is 84Mhz , according to the formula if i want a timer count of 1 second i would need values as PSC = 10000 and ARR =8400 , yet when i insert these values i get a timer of 8.4 seconds ? , but then I inserted values ARR = 10000-1 and PSC = 1000 i get 1 second exact .
‎2022-05-15 12:27 AM
That means that TIM1 clock is not 84MHz as you thought. You can verify it by outputting system clock onto the MCO pin and measure using oscilloscope/logic analyzer.
Check RCC registers content, and frequency of the primary clock source. Try with HSI first, its frequency is known.
‎2022-05-15 1:02 AM
Yeah I had my doubts , but I scratched it out beacuse how can CubeMx get the clock wrong ? Never really checked clock before using MCO pin so yeah , thats a another problem on another thread . So My clock is basically running on 10Mhz ??
‎2022-05-15 1:25 AM
Read out and check RCC registers settings. Check the primary clock (i.e. do you have a 25MHz crystal connected?)
‎2022-05-15 1:31 AM
yes, the 25Mhz crystal is connected and I am using HSE as my clock source ,both in pinnout and clock configuration block, otherwise if connection is issue i shouldnt be getting any clock ? . My clock settings are as show below . Also on the top i've shown my actual CubeMx clock configuration ,which matches exactly with the code generated i believe .
__HAL_RCC_PWR_CLK_ENABLE();
__HAL_PWR_VOLTAGESCALING_CONFIG(PWR_REGULATOR_VOLTAGE_SCALE2);
RCC_OscInitStruct.OscillatorType = RCC_OSCILLATORTYPE_HSE;
RCC_OscInitStruct.HSEState = RCC_HSE_ON;
RCC_OscInitStruct.PLL.PLLSource = RCC_PLLSOURCE_HSE;
RCC_OscInitStruct.PLL.PLLM = 25;
RCC_OscInitStruct.PLL.PLLN = 168;
RCC_OscInitStruct.PLL.PLLP = RCC_PLLP_DIV2;
RCC_OscInitStruct.PLL.PLLQ = 4;
Error_Handler();
RCC_ClkInitStruct.APB1CLKDivider = RCC_HCLK_DIV2;
if (HAL_RCC_ClockConfig(&RCC_ClkInitStruct, FLASH_LATENCY_2) != HAL_OK)
Error_Handler();
