Bug in STM32L051 reference manual descriptions for some FLASH_PECR bits
‎2022-11-18 8:13 AM
The descriptions of FLASH_PECR bits 1, 2 (PRGLOCK, OPTLOCK) on page 103 appear to have the meanings of 0 and 1 swapped. For example, referring to PRGLOCK (Bit1) the RM says:
0: The write and erase operations in the Flash program memory are disabled.
1: The write and erase operations in the Flash program memory are enabled.
Bug-report
Documentation
Flash
STM32L0 Series
‎2022-11-21 6:05 AM
Hello @Community member​ ,
You are right, the sentences are swapped.
The correct sentence should be:
0: The write and erase operations in the Flash program memory are enabled/unlocked.
1: The write and erase operations in the Flash program memory are disabled/locked.
I raised this issue internally for correction in the ticket ID 139382 (PS: This is an internal tracking number and is not accessible or usable by customers).
Imen
Imen
‎2022-11-21 6:05 AM
Imen
Imen
