BSP_QSPI_MemoryMappedMode Enable doesn't work with W25QXX
‎2023-11-29 10:35 PM
I am trying to do a memory map with this board W25QXX and it's not working. For some reason even on the original code we can see the function for BSP_QSPI_MemoryMappedMode have a comment (https://www.waveshare.com/wiki/W25QXX_DataFlash_Board). Any idea why?
I am using this board, with STM32H743IIT the configuration of my QUADSPI is:
QSPI
STM32H7 Series
‎2023-12-10 10:40 AM
this should be the implementation:
‎2023-11-30 2:19 AM
Hello @aabba.1 ,
The shared code isn't supported by ST. But, I noted that the TIMEOUT Counter is enabled in the comment code line, and it mentioned in the STM32F746 errata sheet that Memory-mapped read operations may fail when timeout counter is enabled and the workaround is to disable the timeout counter.
s_mem_mapped_cfg.TimeOutActivation = QSPI_TIMEOUT_COUNTER_ENABLE;
To configure QSPI in memory mapped mode using STM32H743 devices, I advise you to start with an available QSPI_MemoryMapped example in STM32CubeH7 package.
If you using STM32CubeMX toolchain to configure the QUADSPI interface, I recommend you to follow the steps shared in AN4760 precisely section 4. QUADSPI configuration.
Thank you.
Kaouthar
‎2023-11-30 5:29 AM
What's the comment? Imagine I can't get to this on my phone, present better.
Make the command template work in direct mode, this maps directly to how the memory mapped read works, a template it stuffs an address field into.
