BootLoader timeout
yarona
Posted on January 12, 2015 at 09:17
Hi
I am using STM32L151 bootloader.
I wanted to run the bootloader at program start, and if no usb if attached for a certain time
go back to regular application.
Is it possible to configure a timeout for the bootloader?
Yaron
4 REPLIES 4
Posted on January 12, 2015 at 12:43
The System Loader (BOOT0=High)? or your own Boot Loader?
You can decide whether to call the System Loader from your own code, via a button or RAM setting, but it's not going to timeout and come back to you.
How about ST systembootloader, https://community.st.com/t5/stm32-mcus-products/does-system-bootloader-eventually-timeout-and-jump-to-user/td-p/764233
I have the same question, does it even timeout?
hit me up in https://www.linkedin.com/in/javiermu%C3%B1oz/
You are answering for something from 10 years ago i guess.
But best/easier way to do it, or what i do when needed is, in custom bootloader, put the timeout whenever i need. Never tryed a "non-custom" bootloader!
Im not answering, i have the same question.
I really want to use ST ROM systembootloader, im tired of creating a new bootloader evey time i change companies.
