application note and data sheets
billium
In the installed STM32Cube Repository there are hundreds of application notes and data sheets, does anybody know where there is a list of contents?  It would take a long time to open them all to check or get the right grep phrase to search.
2 REPLIES 2
STea
Hello @billium and welcome to ST Community,
In each package installed in the cube repository you will find a release_Notes.html file which has the updates and references to all the useful documentation related to this package in the image below you will find the example of the links to documentation related to Cube_FW_H5_v1.1.1 package for example. if you want to visualize and search in the documentation in all the packages installed maybe you should try to develop a python script.
BR Hichem
Presumably most of this has been spidered by Google, Bing, ChatWTF, etc, use those if you don't have a file viewer, or strong desire to browse / skim everything.
