Alternate microcontroller for STM32G431RBT6
ny851
Would you please suggest us alternate microcontroller for which should be the advance version of STM32G431RBT6 and operating voltage should be more than 105 Celsius.
best regards,
Nisha Yadav
@Peter BENSCH
9 REPLIES 9
Uwe Bonnes
Chief
T3/7 suffix instead of T6 indicates extended temperature range. Look on the website "order direct" for an indication of availability
yes but the controller should be advance in function
So load the MCU finder application, enter your requirements and search yourself.How should other people know what "advance" your need?
Yes you are right. are you talking about ST-MCU-FINDER-PC application? thank you to show correct path
Andrew Neil
:thinking_face:  :thinking_face:   :thinking_face:
sorry it's operating temperature
There's also one for iOS and Android:
https://www.st.com/en/development-tools/stm32-finder.html
Just put "STM32 Finder" or "STM32 Search" or similar into your favourite search engine ...
yes i'm using that application
Peter BENSCH
@ny851 If you are only interested in the larger temperature range, you will find the relevant information on the product website, in your case the variants with 125°C STM32G431RBT3 (tray) or STM32G431RBT3TR (tape & reel).
Hope that helps?
/Peter
