2023-11-16 7:25 AM
the code generated for my channels if i initialize this channels and
hadc1.Instance = ADC1;
hadc1.Init.ClockPrescaler = ADC_CLOCK_SYNC_PCLK_DIV2;
hadc1.Init.Resolution = ADC_RESOLUTION_12B;
hadc1.Init.DataAlign = ADC_DATAALIGN_RIGHT;
hadc1.Init.ScanConvMode = ADC_SCAN_SEQ_FIXED;
hadc1.Init.EOCSelection = ADC_EOC_SINGLE_CONV;
hadc1.Init.LowPowerAutoWait = DISABLE;
hadc1.Init.LowPowerAutoPowerOff = DISABLE;
hadc1.Init.ContinuousConvMode = ENABLE;
hadc1.Init.NbrOfConversion = 1;
hadc1.Init.ExternalTrigConv = ADC_SOFTWARE_START;
hadc1.Init.ExternalTrigConvEdge = ADC_EXTERNALTRIGCONVEDGE_NONE;
hadc1.Init.DMAContinuousRequests = DISABLE;
hadc1.Init.Overrun = ADC_OVR_DATA_PRESERVED;
hadc1.Init.SamplingTimeCommon1 = ADC_SAMPLETIME_39CYCLES_5;
hadc1.Init.OversamplingMode = DISABLE;
hadc1.Init.TriggerFrequencyMode = ADC_TRIGGER_FREQ_HIGH;
if (HAL_ADC_Init(&hadc1) != HAL_OK)
Error_Handler();
/** Configure Regular Channel
sConfig.Channel = ADC_CHANNEL_0;
sConfig.Rank = ADC_RANK_CHANNEL_NUMBER;
if (HAL_ADC_ConfigChannel(&hadc1, &sConfig) != HAL_OK)
Error_Handler();
sConfig.Channel = ADC_CHANNEL_2;
Error_Handler();
sConfig.Channel = ADC_CHANNEL_5;
Error_Handler();
sConfig.Channel = ADC_CHANNEL_9;
Error_Handler();
sConfig.Channel = ADC_CHANNEL_15;
Error_Handler();
sConfig.Channel = ADC_CHANNEL_16;
Error_Handler();
/* USER CODE BEGIN ADC1_Init 2 */
/* USER CODE END ADC1_Init 2 */
i am getting same value for all the adc value
2023-11-21 2:26 AM
Hello @meena,
Here some additional information :
Best Regards,
Pierre
2023-11-20 7:14 AM
Hello @meena,
Thank you for your question!
Here some remark :
Best Regards,
Pierre
2023-11-20 7:21 AM
Thanks for the reply.This is what like I configured The no.of conversion made to 6 also getting same values
void ADC_Vbat(void)
ADC_ChannelConfTypeDef sConfig = {0};
sConfig.Rank = ADC_REGULAR_RANK_1;
sConfig.SamplingTime = ADC_SAMPLINGTIME_COMMON_1;
Error_Handler();
HAL_ADC_Start(&hadc1);
HAL_ADC_PollForConversion(&hadc1, 1000);
Vbat = HAL_ADC_GetValue(&hadc1);
//Vbat = (Vbat * 3.3)/ 4095;
HAL_ADC_Stop(&hadc1);
void ADC_BattIsense(void)
sConfig.Channel = ADC_CHANNEL_3;
sConfig.Rank = ADC_REGULAR_RANK_2;
Error_Handler();
BattI = HAL_ADC_GetValue(&hadc1);
void ADC_ledIsense(void)
sConfig.Rank = ADC_REGULAR_RANK_3;
Error_Handler();
LedI = HAL_ADC_GetValue(&hadc1);
void ADC_Temp(void)
sConfig.Rank = ADC_REGULAR_RANK_4;
Error_Handler();
Temp = HAL_ADC_GetValue(&hadc1);
void Open_Circuit(void)
sConfig.Rank = ADC_REGULAR_RANK_5;
sConfig.SamplingTime = ADC_SAMPLINGTIME_COMMON_2;
Error_Handler();
Opv = HAL_ADC_GetValue(&hadc1);
2023-11-21 2:26 AM
Hello @meena,
Best Regards,
Pierre
2024-07-12 2:01 AM
I use 4 channels of ADC1 in my program. But, when I see the result by HAL_ADC_GetValue() function,
the results of channel0~channel3 of ADC1 are all same.
Could you tell me the reason of this phenomenon?
Thank you!
