A problem with STM STudio
hesam moshiri
When I want to import variables from the .elf file (generated by the TrueStudio, inside the Debug folder) into the STM Studio software, I get the below error. When I press OK and bypass it, it shows a list of variables, but none of them gets imported.
4 REPLIES 4
Yeah, doesn't look to be parsing the .ELF properly, perhaps @ST Community​ can forward to staff
cdmech
Hello Hesam,
Did you ever find a solution to your issue? I have encountered the same issue. Any resolution you could share is most appreciated! Thank you and good luck.
Not really unfortunately
Hello Hesam,
Thank you for your prompt reply. I am sorry to hear that. Let's continue to try and solve the issue. Best of luck to you!
