stm32f7508-DK Audio save in SD card example
Ss.61
I am using stm32f7508-DK
Try to save Audio in SD card
Please suggest the related example will help me to complete the task.
regards
siva
Andrew Neil
Evangelist III
As far as the SD Card is concerned, it's just a file - no different to any other file.
SD Card examples should be easy to find...
Thank you very much for your quick reply,
My concern is in Firmware package (example)
Two Different examples 1.Audio record 2.Fatfsusd
i want to combine those 2 examples
when i try to combine some of the dependency files (header files are not added )
for example i add Stm32fxx_hal_sd.c in Audio Record example (required Stm32fxx_hal_sd.h file is not appear)
kindly help to figure out the problem
thanks
siva
