FAILED import to latest CubeMX 6.2.0 package en.x-cube-usb-audio.zip
MM..1
Chief II
Why nothing work on first attempt???
Howto solve this i need test USB UAC
Edit 1 I try too MX 5.4 same error zip file isnt pack WTF
MM..1
Chief II
ST is bilion budget company and not google random reply is my job.
General description and name this product define as > STM32 USB Device Audio Streaming software expansion for STM32Cube
But product works only with KEIL IAR and AC6 and WTF nothing to do with cube.
Simply renaming and remove X-CUBE from all material and problem is solved.
5 REPLIES 5
Cartu38 OpenDev
Lead II
www.google.com is not your best friend ? => https://www.st.com/en/embedded-software/x-cube-usb-audio.html :-)
Then no chance first guess to get it manage fully by automation because sounds like such deliverable is not a pure CMSIS like pack (no .pdsc file at root of). Guess you have to extract it locally then point to picking material you need (drivers & MWs, examples)
MM..1
Chief II
Was kidding about google despite great help quite often being fair.
AC6 is 100% STM32CubeIDE supported. Let's rely on File > Open Project From FIle System
By the way could you elaborate a bit the way you've get rid of issue ... not clear to me
You maybe dont understand, i have zip file and dont have an info about project inside, i waste my time with try import it to different cubeS
And i solve and unzip mport without trouble to cubeIDE and too i open in KEIL, but my plan is use on other target , and i dont have problem when this zip is named two example usb audio, but sorry you maybe dont see what i.
As no a CMSIS like pack sounds to me no choice ... porting to another target is handmade process.
