About UM2552 sample code
Sodag.1
I am building a USBPD sink with reference to the UM2552, but in the sample code on page 16, it seems that the ")" corresponding to the IF on the 9th line has disappeared, is this a typo? Also, is there a correct example somewhere?
11 REPLIES 11
Sodag.1
Hello @Dominique​
As a result of reviewing the code based on the materials you provided, I was able to extract an arbitrary voltage without using an RTOS.
Thank you for your cooperation.
BR
Nicolas P.
Hello @Sodag.1 ,
I just found your post. Perhaps you've solved your problem since, your last post is old. Should we close the thread ?
Did you have the chance to have a look at this wiki ?
And this github ?
regards,
Nicolas
