2019-09-17 07:04 AM
I am using the STEVAL-ESC001V1 development kit board with a BlueRobotics T200 motor. The motor runs well with the provided SDK firmware and the motor profiler values, but we are having a couple of issues when changing speeds:
Thanks in advance.
2020-01-06 02:03 AM
Hello ASliv.8,
I am dealing with the same problem for like a month now. Do you have any solution?
Thank you in advance!
2020-09-10 02:51 AM
Dear ASilv.8, dear N
Do you have still this problem to solve?
Best regards
Laurent Ca...
2020-09-17 12:52 AM
OK. I consider this post closed. Do not hesitate to answer if it is not.
Best regards
Laurent Ca...
