STM32F303CB Motor control setup can't avoid stalling
‎2019-09-17 7:04 AM
I am using the STEVAL-ESC001V1 development kit board with a BlueRobotics T200 motor. The motor runs well with the provided SDK firmware and the motor profiler values, but we are having a couple of issues when changing speeds:
- The range of the potentiometer maxes out at about 50% turn on either forward or reverse. My PWM range is 1000-2000 and 1500 is "0" since it has forward/reverse.
- When we switch the motor from forward to reverse (and vice-versa) after going at full-speed for a few seconds, the motor stalls. It makes a whinding "whoop" sound. Could this be addressed by Rev-up by FOC? What settings can I change to fix this?
Thanks in advance.
STM32 Motor Control
STM32F3 Series
‎2020-01-06 2:03 AM
Hello ASliv.8,
I am dealing with the same problem for like a month now. Do you have any solution?
Thank you in advance!
‎2020-09-10 2:51 AM
Dear ASilv.8, dear N
Do you have still this problem to solve?
Best regards
Laurent Ca...
‎2020-09-17 12:52 AM
OK. I consider this post closed. Do not hesitate to answer if it is not.
Best regards
Laurent Ca...
