project generation issue
‎2023-09-19 4:45 AM
when i generate the project in the mcsdk then it continue showing like this .
i have wait long time its still showing same, what i am doing wroing ?
MCSDK5
‎2023-09-19 5:05 AM
hello @Ranjeet Singh
you seem to be using a version 5.Y.4 or close, but these versions do not support CubeMx 6.9.1, download CubeMx 6.4.0 then select it, the generation should work better
‎2023-09-19 5:05 AM
‎2023-09-19 9:22 PM - edited ‎2023-09-19 9:22 PM
thank you @Zied b.
