2020-02-01 3:38 AM
Hi, i am trying to control bldc motor sinusoidally. I completed with 6 step commutation.
I asked help in stm32 forum recent, but none helped. I have learned something in sinusoidal bldc control.
I don't know where i am wrong, guys help me to solve this problem.
2020-02-01 4:50 AM
The required current (sine amplitude) should be dependent on the required torque and speed.
2020-02-01 4:50 AM
2020-02-02 11:00 PM
THank you for your response . Ok piranha what you are saying is, running bldc motor under open loop sinusoidal configuration is accurate and will consume more current. Now i will try to synchronize the hall sensor data (RPM) with sin table. Can you give some advice for this.
2020-10-16 1:01 AM
Dear @Bud
Did the @Piranha 's answer help you to solve yor problem?
Best regards
Laurent Ca...
2020-10-30 3:25 AM
Dear @Bud
I guess it did, therefore I consider this thread closed.
If not, feel free to reopen it by posting an answer.
Best regards
Laurent Ca...
