2024-05-02 05:12 PM
Hi everybody,
I was looking at the documentation for the MCSDK6 (great work btw), in particular to the Motor Control Protocol Suite section.
Everything is well documented, however, I was wondering if is there any DLL available in order to facilitate the communication between a PC application and the microcontroller.
Thank you,
Andrea.
2024-05-03 12:46 AM
Hello AndreEPC-CO,
Unfortunately, apart from the MotorPilot tool embedded in MCSDK, we provide nothing more to facilitate communication between the microcontroller and a computer. However, MotorPilot has been developed in a way that allows you to modify and adapt the tool to your needs.
We do note your request nonetheless, and this will be part of further development on our side.
2024-05-03 12:46 AM
Hello AndreEPC-CO,
2024-05-03 09:33 AM
Thank you Gael for the answer!
I'm really looking forward for you to release a library or something, because you've done a really nice work with the protocol and having a PC library would open a lot of possibilities.
Andrea
