Jan 6, 2025 9:51 AM UTC
Missing library "TrajCtrl.h" when creating project on kit STEVAL-ETH001V1
I bought the STEVAL-ETH001V1 kit on digikey. I also downloaded the firmware for the servo drive. However, when I build this project using keil c, the "TrajCtrl.h" library is missing and this library is not provided in the firmware.
I would like to ask where I can find this library or can someone help me?
GMA
GMABest answer
Jan 7, 2025 4:03 PM UTC
Hello @phamtutailtvm,
Loading project on IAR, PositionDemo.c file, that uses TrajCtrl.h file, is not part of the project. Could you try without it?
If you agree with the answer, please accept it by clicking on 'Best answer'.Best regards.GMA
GMA
GMABest answer
Jan 8, 2025 7:38 AM UTC
Why don't you provide that file in the firmware? I use Keil C to run and debug for my project. So i need that file to continue my project.
If possible, can you provide me that file?
