2018-04-21 01:53 PM
I set up X-CUBE-MCSDK_v5.0.3 from st.com.
MCSDK 5.0.3 is seen as 5.0.2 in About windows.
Why?
#mcsdkSolved! Go to Solution.
2018-04-23 04:48 AM
Hi Vitaliy,
X-CUBE-MCSDK is a combination of the firmware library + the ST Motor control Workbench.
The version printed in the About window is the workbench's version.
If you generate the code you will see a detailed version of the various parts (see attached picture).
5.0.3 refers to Firmware library.
Cedric
2018-04-23 04:48 AM
Hi Vitaliy,
Cedric
2021-06-27 10:30 PM
The question has been moved from the "Motor Control Hardware" section to the "STM32 Motor Control" section (the question is about the STM32 MC SDK).
Best regards
